help me with 6630
4 replies · 1,612 views · Started 09 October 2005
Hi,I'm a new user for nokia 6630 and I've no idea how to download programs from my pc to the phone... can anyone help me?
In details pleaseeee
install pc suite(came with the phone)
and use "install applications or file manager"
you have to connect your phone with the datacable off course
aswany wrote:Hi,I'm a new user for nokia 6630 and I've no idea how to download programs from my pc to the phone... can anyone help me?
As suggested, you PC Suite, but download latest version from www.nokia.com/pcsuite, most likely the version in sales pack CD is old, better use the newest one.
YOu can connect with DKU-2 cable (buy it if there was no USB cable in sales pack, I hope there was. Also you can use Bluetooth connection, but if you are not familiar with using PC and phone, I suggest cable, it is easier.
Thank you for ur responding, I downloaded nokia pc suite v 6.4.8 and installed the driver for my phone , I've dku-2 cable but when i'm trying to install any application like themes or any other program with .sis nokia application installer write operation failed.
Check also on the phone that application installation is enabled: menu > Tools > Manager > Options > Software installation > On
