http://europe.nokia.com/nokia/1,8764,47878,00.html
Wouldnt it be cool if nokia made a WiFi version which would allow you to connect to hotspots and make lan connections.Id buy one 😃 😃 😃
paddy4 wrote:http://europe.nokia.com/nokia/1,8764,47878,00.htmlWouldnt it be cool if nokia made a WiFi version which would allow you to connect to hotspots and make lan connections.Id buy one 😃 😃 😃
They just did that, check out nokia E60 !!
densev wrote:They just did that, check out nokia E60 !!
No!
I mean an addapter which snaps on to the popport of s60 nokia phones and allows WiFi connectivity:icon14:
That would be really cool.
Wifi via Popport
infrared via popport
memory card reader or usb hub via popport
