Is it just my phone that does this.
2 replies · 1,106 views · Started 10 October 2005
When ever someone try's to call me my phone never rings and it always goes to the answerphone iv'e tried formatting and restoring default settings what going wrong. Is a firmware bug or my usim?
My firmware version is 2.04.15 04/03/05
Forgive me if you think that I'm patronising you, but the first thing you should check is the Menu -> Tools -> Settings -> Call Divert -> Voice Calls -> All Voice Calls -> Check Status. If that comes back as Active, then select All Voice Calls -> Cancel.
Also, check that your phone isn't offline (though I guess you've already checked this) and ensure that the person who is phoning you isn't in a group for which your profile has not been set to alert (Profiles -> Your profile -> Options -> Persionalise -> Alert For).
Ive tried that lots of times and it says theyre cancelled but its still happening. I cant think of anything apart from the sim being faulty. But its only been happening since i set my voicemail up anyway.
Anything i could try to get it working?
