Is there anyway to re-install the default software / download it from somewhere that comes as standard on the new N90's MMC
IN error I formatted the card to remove some data I transferred to it, not realising that most of the original application software also comes loaded onto the MMC
I;ve been able to source some of the stuff but not all of it
any help would be appreciated
currently missing
adobe reader
opera
all the video messages
and other stuff I;m sure
maybe theres a way someone could copy there mmc for me ??
ccarcher wrote:Is there anyway to re-install the default software / download it from somewhere that comes as standard on the new N90's MMCIN error I formatted the card to remove some data I transferred to it, not realising that most of the original application software also comes loaded onto the MMC
currently missing
adobe reader
opera
you can visit nokia.com
all programs for N90 are there except 'Opera-Mini'
the videos you are looking for are the same of that of N70.
Install the N90 Opera from Opera.com
Opera mini is for other phones.
The rest you can get from Nokia.com support section.
fdxd wrote:Install the N90 Opera from Opera.comOpera mini is for other phones.
Please note that the currently (as of 21.10.2005) avaliable version of Opera on the Opera site is not compatible with N90. Apparently Opera software will release a version of Opera that is compatible in the coming week. This version will also support the resolution of the N90 screen (embedded version does not...).
