Hi there,
i've set my cell to auto lock after a few minutes.
But i do not like that MAXI KEY that fills the whole desktop.
Browsing my Z: partition i found a folder called Autolock (Z:\System\Apps\Autlock) and also found the key picture which i called AutoLock.mbm.
Now, what to do to replace that .mbm with a transparent picture?
Can Paint Shop Pro create .mbm pictures?
Thanks in advance
lsangio 😊
Paint Shop Pro cannot create .mbm files, but the Symbian SDKs have tools for that. However, you can't replace anything on the Z-drive (it is read-only memory, ROM).
N/A wrote:Paint Shop Pro cannot create .mbm files, but the Symbian SDKs have tools for that. However, you can't replace anything on the Z-drive (it is read-only memory, ROM).
ok, i'll stick with that one :frown:
thanks for posting
lsangio 😊
I don't think I understand your post. My 6630 displays no maxy key when it goes into screensaver mode. The standard screensaver is a line with date and time but you can replace it with nicer screensavers (some of them are even freeware)...
UA
Utenteanonimo64 wrote:I don't think I understand your post. My 6630 displays no maxy key when it goes into screensaver mode
UA
no doubt. But when you set your cell to auto lockup after a few minutes...
try and see!
cheers
lsangio 😊
Now I understand.... you are talking about phone lock... the thing where you need to type a code to unlock the phone?
Sorry but I have never used that feature on my phone so I didn't know about this maxi key thing....
UA
