Pre-installed games
2 replies · 1,859 views · Started 12 October 2005
When looking thhrough the application manager on my 6680 i noticed that there are a number of pre installed gagmes, (MVPS-Getway, entertainment etc..) however i have no idea how to run them, could anyone be so kind as to point me in the right direction.
Much appreciated all
Theo (Nokia Virgin)
It may be that thse are just sis files in the App Manager (not sure as I haven't come across this before). You should be able to install them by selecting them from the App Manager and which point they would appear as icons in the Menu screen.
hi.........
they are not games
they are movie transparencys that you can stick your photo's or movies into
try it its good.
if you goto imaging folder, then movie, then quick movie, you will find them there and if you click one it will insert the last photo or movie you took (whichever was last)..
yet if you click custom movie you can choose the pic or movie you wish to use before applying your choice of transparency......
hope this explains it for you
