uninstall PC suite 6.6
5 replies · 3,730 views · Started 12 October 2005
How to uninstall pc suite 6.6?
It seems that install shield exit without removing pc suite 6.6.
Any guide to uninstall that correctly?
kkboy wrote:Successfully Remove PC suite. Install a new version Nokia_PC_Suite_66_rel_18_eng but cannot detect my bluetooth..
kkbouy, if you want some help for your problem in this forum, you need to provide details, otherwise we can only symphatize that your BT does not work.
manta wrote:kkbouy, if you want some help for your problem in this forum, you need to provide details, otherwise we can only symphatize that your BT does not work.
I am using SP2. Installing BlueSoleil_1.6.1.4 for my bluetooth adapter.
When I config BlueSoleil on PC suite, it can find my devices but cannot pair my device with PC suite.
