Hi there,
does anyone know how can i exclude my screensaver?
I do not like it and furthermore it's even useless in my opinion.
In my SETTINGS\DISPLAY menu i see:
- brightness
- timeout screensaver (1 to 30 min)
- timeout light
but have no chance to select/disable the screensaver 😡
any help?
thanks in advance
lsangio 😊
I don't think is possible, although it is operator branded it should be removable if you delete the correct files.
Yes, I also don't understand why there is no option to turn it off. I tried killing the task in fexplorer, but that didn't work either.. So strange!
to change the screensaver go to Themes\selected theme\edit\screensaver.
ya now have option of either date and time, text or operator.
ya cannot delete screensaver as it is set in rom by nokia and operator.
it can be changed though using programs like powerlock which uses a fully customisable screensaver that over rides the nokia/operator version
any idea where to download screensavers from without the need for a 3rd party proggie and how to install them?
