Hi all, have had a look around and can't find the info... does anyone know how long you can record a video for on the N70?
Steve
Steve
An hour or that's what the camera app seems to be indicating on my N70 for "Normal" and "High" recording modes. In "Sharing" mode it says 35 seconds (that's only useful for MMS messages, because it reduces also resolution and quality of the video).
N/A wrote:An hour or that's what the camera app seems to be indicating on my N70 for "Normal" and "High" recording modes. In "Sharing" mode it says 35 seconds (that's only useful for MMS messages, because it reduces also resolution and quality of the video).
Thats great, thanks.. same as the 6680 spec then!
Just need to decide between the 6680 and N70.
Primarily I want a phone that will run TomTom, have all my contacts and calendar stuff on it, and then basic PDA functions (word excel etc).... looks like this one could do the job.
Hi!...
It�s not just like 6680 ...
N70 It�s MUCH BETTER! Quality and fluid video...
AND... BIGGER if you want ... up to 352 x 288 Video Resolution for recording ... then if you see that video on the PC look really great ... not like the tiny 176 x 144.
Check this link to see some samples... the first sample there it�s good...
the others have some freezing problem because they test a prototype phone...
http://www.mobile-review.com/review/nokia-n70-camera-en.shtml
cya!
AEFOX wrote:Hi!...It�s not just like 6680 ...
the others have some freezing problem because they test a prototype phone...http://www.mobile-review.com/review/nokia-n70-camera-en.shtml
cya!
Great, thanks for the link..... reckon that puts in 1st place for me. I'll be onto Vodafone first thing on Monday!!
How are you guys getting an hours worth of video??
Mine said 18 mins when I first used, with about 8 minutes left?!?!??!
Is it an hour max, but you must have a card to allow for it??
Steve
gadget_sa wrote:How are you guys getting an hours worth of video??
Mine said 18 mins when I first used, with about 8 minutes left?!?!??!Is it an hour max, but you must have a card to allow for it??
Steve
Clips can be recorded for up to 1 hour dependedent on how much space you have on your memory card
