In Trouble...
4 replies · 1,485 views · Started 14 October 2005
hi all, I installed a NFS theme from some website on my N6670. It was working fine, then I decided to change the theme. When I changed the theme to my default phone theme, then a message was displayed that the memory card is corrupted; so i formatted the memory card and restored original phone settings. Now the mobile is working fine, but in the process I lost all the 3rd party applications. how can I restore all the 3rd party applications like quickoffice or netfront that's free with the phone.
Thanks in advance.
Rafe wrote:Some of these are available on the the Nokia support / download page for the 6670.
See http://europe.nokia.com/nokia/0,,64488,00.html
Thanx for the info, but is there any way of having the previous settings back( when I bought the phone, it had quickoffice, netfront, and various other applications). I have problem with memory management, I installed quickoffice, and few other aplications then I tried to install netfront and the message is displayed that I have less memory for the application; but I had all these applications installed before without any memory trouble. Please tell what to do to get things as it was before.
There is no other way. You have to reinstall them yourself.
Make sure you have installed them to the memory card or you will quickly run out of memory.
If you're still out of memory it may be because your C drive is too full. You should consider deleting some large files (photos are a usual culprit).
You need to be more specific about the error message you had (and when) I suspect you may not have enough memory to transfer and install the NetFront SIS file, but I can't be sure.
Rafe wrote:There is no other way. You have to reinstall them yourself.
Thanks, I installed all the applications again, many of them to the MMC card.
