Hi!
I am testing my app for symbian signed with LowMem tool. It is showing a
KERN-EXEC 3 panic when I execute the following code. PLease help with where
I am going wrong.
TBool CSomeClass::AppInstalled(const TDesC& aAppName)
_LIT(KSQLInstall,"SELECT Instal FROM App WHERE Name='%S'"😉;
TBuf<63>* installSQL=new(ELeave)TBuf<63>();
CleanupStack::PushL(installSQL);
installS QL->Format(KSQLInstall,&aAppName);
RDbView tmpView;
TInt retCode=tmpView.Prepare(iEngineDB,TDbQuery(*installSQL) );
CleanupStack::PopAndDestroy(installSQL);
if(retCode==KErrNone)
if(tmpView.Unevaluated())
tmpView.EvaluateAll();
while (tmpView.NextL())
tmpView.GetL();
if(tmpView.ColInt(1)==0)
tmpView.Clos e();
return ETrue;
else
tmpVi ew.Close();
return EFalse;
Thanks and Regards,
lalit
> I am going wrong.
I guess this should better go to c++ subgroup instead..
This could get easily overflowed.. see max app name length.
> RDbView tmpView;
You should use CleanupClosePushL() here (if NextL() leaves, there won't
be a proper cleanup)
> tmpView.GetL();
> tmpView.Clos e();
> return ETrue;
> else
> tmpVi ew.Close();
> return EFalse;
> Thanks and Regards,
> lalit
David Caabeiro
www.PushL.com
> Hi!
Hi to you too.
> where
> I am going wrong.
Why allocate the descriptor dynamically? Just allocate big enough descriptor
from the stack. Or use HBufC instead.
> RDbView tmpView;
From TDbQuery documentation:
TDbQuery(const TDesC& aQuery,TDbTextComparison
aComparison=EDbCompareNormal);
Description
Constructs a query object from an SQL string and a text comparison mode.
Note that no copy is made of the descriptor passed; it is stored by
reference in the query object."
So when you pop and destroy the dynamically allocated descriptor, the
reference to the descriptor in TDbQuery becomes invalid.
> Thanks and Regards,
> lalit
Hope this helps.
