I am developing an audio streaming application. The streaming is implemented
in a different thread. It works fine on all the devices that I could test
on, namely, 3650, N-Gage, 6600, 6630 and 6680.
When I run the same application under the LowMem tool, the test runs fine on
the 3650, N-Gage and 6600, however, on the 6630 and 6680, the phone seems to
restart as soon as the
"Memory Full, Close some applications and restart"
message pops up.
I have noted that the restart happens only if data is currently being
written to the output stream (when I commented out the
CMdaAudioOutputStream's WriteL() call in the build, the restart stopped
occurring).
I can't seem to figure out why such a problem will occur only on these 2
devices(6630 and 6680), when tested with LowMem.
Any advice will be greatly appreciated.
Best Regards,
Sameet.
Did you get this fixed? I have some ideas, but I would need more detail on
your code structure.
"Sameet" <[email protected]> wrote in message
news:Qedy%23JL0FHA.2932@extapps30...
> Hi,
> implemented
> on
> to
> message pops up.
> occurring).
> Best Regards,
> Sameet.
Thanx for the reply. I still haven't found a good enough solution to this
problem.
Which specific areas do u suspect, could be the cause of this problem? As
in, what part of the code structure do u need to know about?
Thanx for the help,
Best Regards,
Sameet.
"Jeff Brown" <[email protected]> wrote in message
news:77ZEvhZ3FHA.2920@extapps30...
on
> news:Qedy%23JL0FHA.2932@extapps30...[color=green]
> > Hi,
> > implemented
> > in a different thread. It works fine on all the devices that I could[/color]
test[color=green]
> > When I run the same application under the LowMem tool, the test runs[/color]
fine[color=green]
> > on
> > the 3650, N-Gage and 6600, however, on the 6630 and 6680, the phone[/color]
seems[color=green]
> > to
> > message pops up.
> > occurring).
> > Best Regards,
> > Sameet.
>[/color]
