Run Applications from MMC?
1 replies · 1,630 views · Started 15 October 2005
I got my n-Gage QD the other day and I threw a couple of Jars on there for some games I bought. My question is... Can I execute (install) these from the MMC card? I do not have a USB dongle as ofyet, and I thought maybe I could just copy them to the card from my computer, and istall them?
They are in JAR format.
I am sure this question has been asked before, but I could not find someone that was looking for the same answer.
Thanks much.
Yes u can. Install the app FExplorer http://www.gosymbian.com. FExplorer app is free. FileMan http://www.symbianware.com or SeleQ http://www.Ximplify.com or kind of apps that can explore all of the drive(mmc) in ur phone. Like 'windows explorer' in windows. Find or browse the source of the app that u want to install it, open it using one of the apps above.
Yes, u can. Put the app in the root drive of ur MMC('e:'😉 or drive c (C:\nokia\install\). Open 'manager' (menu --> tools --> manager). The apps's source will be show there. Choose 'options' --> 'install'
Just use FExplorer or FileMan or SeleQ. Point to this apps and then execute them ('options' --> 'Open'😉
