Which operators lock the N70?
15 replies · 3,575 views · Started 16 October 2005
n70 on vodaUK is definately locked
note1: due to my previous experience with my 6630; due to nokias new locking mechanism, it would be impossible to unlock it using the unlock calculators floating on the web
note2: my bro got his 8800 on 02 the other day and its unlocked; you can draw your own conclusions from this 😊
It does somtime depend on who you buy it from.
Generally when sold direct from the network they are locked, but often 3rd party retailers use unlocked stock, especially early on in a phone's market life.
Rafe wrote:It does somtime depend on who you buy it from.
very true
so i will just clarify that both myself and my brother bought the phone directly from vodafone and 02 respectively.
Mines Locked to Vodafone too......
I noticed in the menus"Tools, Settings, Phone, General" that there is a function to "Delete Operator Settings"
Does anyone know what will happen if this done??
Steve
i just received my unlock code
so vodaUK N70's can be unlocked for £19.99
I would guess it deletes the WAP/SMS/MMS/Internet/GPRS settings?
why would u do that; it definately doesnt remove the SIM Card Restriction
I'm sure I read somehwere (don't ask where cos I can't bloody remember now!!) but if you delete the operator settings, it apparently "could" unlock some menus that have been restricted?!??!
Not sure what, and not sure I want to try it so soon....
Maybe someone who is offline at the moment might be able to answer that one.... hopefully!!!
i know when you swap out the memory card for one large enough for a few albums of mp3s you loose loads of software - that happened on the 6680 i had for a week b4 the n70 arrived
Surely you can copy the old memory card onto the new one to avoid this happening.... I know a mate did it on his 6630?!?!?
Please tell me you can!!!
i tried copying the content of the mmc card that came with the 6680 i had
onto a 512 card
but it didnt work
all the apps appeared at the top level - no correct icons
and they wouldnt run
Now thats not what I want to hear.....
Now I'll have to work out whats on the card and trying and get the software from elsewhere...!!
Thats an absolute poor deal!!!
That could make sense..... I'm guessing if the 6630 allows it on a PC then so should our glorious N70......
I copyed the contents of the supplied 64mb card on to 256mb card using my PC card reader.
all worked fine
