I'm still having problems listening to any stations on the N70.
Can people who are receiving anything please post the frequency of the stations they can pick up?
neatheyc wrote:I'm still having problems listening to any stations on the N70.I pick up many frequencies. However, this is very much dependent on where in the world you happen to be. That is, if you are not in the same place (or even country) where I am, listing local radion frequencies makes little sense. So, look up a local radio station frequency guide and try those (or try the built-in station directory, if it lists stations in your geography).Can people who are receiving anything please post the frequency of the stations they can pick up?
i have great connection with mine. =)
its maybe im located in dallas..
Cheers guys. After I posted this, I went home and tested it anyway and was able to find loads of stations just by picking it off the station list it provides. So now have the likes of capital one, radio 1, heart fm, etc.
Haven't found a FM station that does the football on saturdays though?!
Is it possible to listen to the radio using a bluetooth headset?
Or does it have to be a wired headset for the cable to act as the antenna?
If so can you pug in wired for the antenna - then use bluetooth to listen?
Cheers.
willbrady wrote:Is it possible to listen to the radio using a bluetooth headset?
Or does it have to be a wired headset for the cable to act as the antenna?If so can you pug in wired for the antenna - then use bluetooth to listen?
Cheers.
im pretty sure you can. and to the football question, it support fm not am..most talk show happens on am station =)
6680toN70user wrote:im pretty sure you can. and to the football question, it support fm not am..most talk show happens on am station =)
Yep I know that. I usually listen to talksport or used to listen to capital gold on AM. Just wondered if there was a footy one on FM.
