What is the best way to delete items from ur Nokia 9300???
5 replies · 1,940 views · Started 17 October 2005
Because I just got my new N9300, I was trying out some things...
I installed Bounce (just to see what game it is) and didn't like it so i deleted it again.
Now, the question is, what is the best way to delete files from your N9300?
taipan wrote:Hi,
Files or apps? For apps, simply use the Application manager. For files, use the File manager.
Btw, I think Bounce is one of the best games Nokia have made.
If files, I find through the PC suite. Highlight and hit the delete button. Couldnt be easier 😉
where you can force the OS to show all files? I assume it's "semi locked" like M$ does with viewing folders?
Matt
Sy4 wrote:where you can force the OS to show all files? I assume it's "semi locked" like M$ does with viewing folders?
Matt
The built-in File manager is not locked at all. It is right there under settings (Menu - Tools - Settings - Show system directory - Yes). There is even a 'hack' to show the ROM drive (search the forum).
