Problem with email
3 replies · 1,389 views · Started 18 October 2005
I'm kinda new and search the forums for a few hours and couldn't find any answer to my problem. So I will try to explain my prob. as best I can.
1.) I set up gmail on my 9500 no prob. I can retrieve my mail and everything fine. But when I try to send an email it says "Problem sending message System: Disconnected" but when I look in my sent folder it says it was sent. And when I send a test email to another email account. It's there. Does anyone know why it does this?
2.) I am using automail. It works great but I have one prob. It retrieves mail fine but when it checks for mail the next time it will delete the mail on my phone. Even if I haven't even read any of the mail. So if I don't check my mail every hour I wont even know if I got any mail. The settings in gmail are "Enable POP only for mail that arrives from now on." Is it supposed to do that?
Any help would be great. Thanks in advance.
DaLarr wrote:2.) I am using automail. It works great but I have one prob. It retrieves mail fine but when it checks for mail the next time it will delete the mail on my phone. Even if I haven't even read any of the mail. So if I don't check my mail every hour I wont even know if I got any mail. The settings in gmail are "Enable POP only for mail that arrives from now on." Is it supposed to do that?
Thats a problem with gmail,
If you download e-mail from gmail, even if you ask it not to delete it from the server, gmail will still delete the mail, so when it looks the second time, the e-mail that was then has been deleted and so Automail will do the same,
I have a similar problem, I can't download my e-mails on my laptop and computer, only one,
You'd need to contact gmail and see if they are gona change it,
Carl,
I get the complete opposite.
I cant receive, it says there's an error disconecting....
Yet I can send email fine.
This is from a private mail server i own.
Any ideas?
Matt
