is it possible to delete the default ringtones from factory in c:\ or d:\ ?
if yes, what directory the ringtones is in?
Deleting Ringtones
Someone correct me if i'm wrong, but the Default (Ones that come with your phone) are kept on the Z: drive.
You can't delete them, they're in ROM (read only memory)
Why would you anywayz, they don't take that much space.
hey guys! what kind of music ringtone ( hip-hop,pop,classic etc.)! i got the midi file of busta rhymes break yo' neck! it's great and loud so you can hear it whereever you are! never miss a call!!
Anyone from got some SMS ringtones?? i mean i can take every ringtone i want but they're just too long!
Well you are editing your ringtones right? i mean cutting them and making them smaller, for that you can use a simple software that comes with every windows, Sound Recorder. you can cut from a point to the end or from a point to the beggining.
heres a cool site for WAVs: www.ilovewavs.com
to be honest, no! i downloaded those midi files from the net using google and search for midi files! yes it takes a lot of time to find some good ones but since i've found that ringtone i'm very happy with it!!
i don't have a software for editing tones!!
Try anvilstudio for editing midis, its free.
http://www.anvilstudio.com/
Oh thanx! i'll try it at home!!
