I attach the midi file.
It can be played on PC, but not my 7650, showing general system error
anyone help me try it, is it playable on your phone?
Playing Midi
Same here, i just put it on my phone and it gave me a general system error, then a recorder error!
weird :-?
I've seen that before, only with wav files then.
Somehow there are different kind of wav's and midi's. Be sure if you make one of those that u use the standard windows wav of midi format. Not some (new) compressed wav of midi.
If the wav-file doesn't work the reason is probably that wav is in "stereo-mode" and 7650 can't handle stereo files! You can change the stereo-mode whit GoldWave; just save in "8bit, Mono, Unsigned"-format.
Edit:
The midi-file is probably broken. I get the station.mid work whit AnvilStudio: I used the "File" --> "Repair song..." and save it again.
Links:
You can get GoldWave from here and AnvilStudio from here (FREE!!!).
[quote="Urpo"]If the wav-file doesn't work the reason is probably that wav is in "stereo-mode" and 7650 can't handle stereo files! You can change the stereo-mode whit GoldWave; just save in "8bit, Mono, Unsigned"-format.
Edit:
Links:
You can get GoldWave from here and AnvilStudio from here.[/quote]
Very cool!. thanks for putting down all the effort! just one question, is it working now. lol, havent tried it on my phone.
Yes it works, I tested it whit my 7650.
Did you guys noitice that repaired file's size is half of the oginal file...
thanks, i try the anvil studio ... the best midi editor i have ever seen 😃 😃
Yeah, thats right!!! Free, simple, easy to use, lots of functions........
Anyone know how to make midi shorter (cut in some part) using Anvil studio? Please explain.
Thanks in advance :roll:
i edit my midi using midi notate software
and is good software to.. for editing midi
you can remove or cut some note... 😮
here some midi..
[quote="lookman"]Anyone know how to make midi shorter (cut in some part) using Anvil studio? Please explain.
Thanks in advance :roll:[/quote]
Ok, this is for AnvilStudio:
"File" --> "Truncate Song" -->
-> "Delete from Start to current position"
or
-> "Delete from current position to End"
You can easily to jump good position in midi by clicking the "Time:"-box.
[quote="Urpo"][quote="lookman"]Anyone know how to make midi shorter (cut in some part) using Anvil studio? Please explain.
or
You can easily to jump good position in midi by clicking the "Time:"-box.[/quote]
It really works, thanks a lot m8 😃 😃 😃
Is there also an option to change the volume of the midi file with anvil studio?
[quote="goldfinger"]Is there also an option to change the volume of the midi file with anvil studio?[/quote]
I'm not sure but I think that you can't change the "main" volume of midi-files... You can only change the volume of the tracks on the midi.
now i'm use ringtone studio from wilpalm
to increase the main volume 😮
