N70 Bug???
7 replies · 2,598 views · Started 19 October 2005
Hi
Owners of N70 out there, I would greatly appreciate if you could give me some feedback if this happens to your phone.
Does your N70 periodically revert to the "Menu" screen even if you have exited to the "Active Standby" screen? I am in my Active Standby screen and all of a sudden the phone lights up and I am in the Menu screen instead. It is really irritating as I have to hit the Exit button to go back.
capkapak wrote:Mine does not do that as well.
What SW version are on your N70?
Try *#0000# and post the result.
I don't have that problem with my N70... There might be a "bug" with yours, maybe
there is something wrong with the Symbian-Meny button on yours..
zipmail wrote:Hi
ok did u install your virus guard on de n70
if not go to office and install it der is an icont der called security and clcik on it and it will install de software after dat do a virus scan
zipmail wrote:Hi
that's interesting. could it be you accidentally press the menu button? did you keypad lock yr phone?
