Cannot Install Applications
0 replies · 1,966 views · Started 20 October 2005
hi,
I have a 6630 which was working fine till I got a new 256MB card and was transferring data from my old 64MB card to the new one. I had earlier installed all my applications on the Memory Card.
I shifted all the data you can see using Nokia PC Suite and was trying to install the applications on the new card. But when i did that I get an error saying ' Installer : System Error (-1003) '.
Then I thot that since I had installed the application on the older card earlier, I should uninstall it using the Application Manager. I did that but the system would refuse to install the application giving the same error.
Then i switched back to my older card and tried installing another application and it still gave me the same error. So now am assuming that the system installer itself is not working.
any ideas how I can get it back working. :frown:
Thnx
ankz
