Cant seem to backup my communicator to PC nor to Memory card..
Anyone have any ideas what files/folders I can move from communicator to my PC via PCSuite.. reformat 9210 or upgrade it.. then try to move folder from pc to memory card so I can restore.
Is there a file that is in the way of my backup process that I can possibly delete.
the only thing that works... is a sync with outlook for contacts. not good enough for me.
my 9210 halts all the time and I have to remove battery. I use v3.54. I have 1600 contacts and it goes very slooow. they told me to move my contacts to a contacts folder on the mem card.. but then there is no caller id cause symbian doesnt lookup memory card contact folders... (nokia/symbian fix this)
also.. from front of phone.. when you wish to write sms.. u cant lookup addressbook and type in name of person to lookup... it only allows u to enter number or browse addressbook. (nokia/symbian fix this)...
