can it be done ???????? like i want to know if i do it what would happen would it work ??? i got a 6600 and a n-gage qd just want to do stuff to the qd
theme sis file from a 6600 installe on n-gage
No, Series 60 themes will not work on an N-Gage & never will.
well i want to know if i get the theme sis file that can install support for themes from my 6600 can i use it on my n-gage
i found the system file using a file explore app wanna know it it will work or not if it can io can upgrad the os to using other files i see there
The answer is still no.
dude you do not get me i went in to the explorer on the phone went in to z:\system\install and copy series60skinsupport.sis
by z: i mean the drive that holds all the phone install files for when you format
hope it is explained better now
There is no kind of .sis file that you could get/find/copy from anywhere and install on an N-Gage to get S60 themes to work.
Feel free to keep on searching, but you're wasting your time.
It doesn�t work. Is possible to find on N-Gage forum, two files, one is N-Gage themes (not relly themes, but a way to make standby screens with some different icons) and another one is N90.sis - that make the icons of N-Gage like N90. The last one seems have a v�rus - check first.
