I can connect my Sendo X to my computer via bluetooth and synchronize my data etc. I installed AvantGo the other day. But even though I am connected via BT, AvantGo wont sync. It says sending data and comes back to home screen. Has anyone gotten Avanto to sync with their Sendo X.
How to sync AvantGo with Sendo X
Make sure you have enough ram free for the sync, because it takes a lot, also check if you choose to sync using GPRS or not, and try using the cable.
I have no issues syncing my mobile with avantgo using BT, neither the cable.
When synching via BT what access point do you use??
None, it detects it is connected to a computer, the first time you must sync using the cable, so Avantgo configure to get the info from another computer and no directly from the web, once you did that everytime you get connected using BT just press sync, it must not ask you for an access point
