Got my phone on Vodafone, and when the phone goes into screensaver mode before it just shows the time and date across the screen, I get lots of Vodafone symbols flashing around... very bloody annoying.
Any ideas how I can get rid of this?
I can't shorten the screensaver time to less than a minute and it makes me go all googly eyed when I look at it.
Please help!!!
Steve
under options/themes theres an "power saver" option which should be set to vodafone
just select either text or date
im not sure, havent tried it tho
Once again, thanks... now thats less off putting!!:icon14:
i am having the same problem but can't find where i can change it - please help, its very annoying
Select: Menu
Select: Tools
Select: Themes
Once in themes, press "OPTIONS", "EDIT"
Scroll to "POWER SAVER"
Change it to "DATE & TIME"
excellent, thank you very much
anyone know how to make this date (and particularly) time larger? sony ericssons have the time much larger - which is more convenient when you're blind at night and don't want to squint to get the time off the phone. thanks!
Had the same pproblem. Thanks!
Try shareware screensaver at gosymbian.com
Highly recommended.
