SCREEN SAVER SETTINGS!!!
10 replies · 5,115 views · Started 14 November 2002
Erm.... could anyone assist me on what the specifications are concerning in developing a screen saver? What size does it have to be? I've done one 174 x 132 but when it the screensaver activates, it's small and displayed in the left side corner of the screen. I tried the matrix one and that seemed to have the same problem.
Cheers in advance. 😃
[quote="Neo_lyptic2002"]turn all the indicators off, trust me 😃[/quote]
What do you mean turn off all the indicators??
Actually, nevermind. I figured it consumes less memory by creating a folder and placing the gifs in there and then setting your screen saver to slide show. The screen saver will read the images in alphabetical order so make sure you name the images in sequence eg. 0000.gif, 0001.gif, 0002.gif...... and so forth.
Doing it this way achieves desired effect and plus it doubles up if you happen to want the image(s) on it's own.
[quote="Markjsca1"]can you e-mail me what i gotta do to be able to set my background to slideshow?
could you e-mail me the reply to [email protected]?
Thanks in advance[/quote]
You need a screen saver proggy. Here ya go 😃
[quote="Markjsca1"]What what? where is it?[/quote]
You probably can't see it because you're not a registered member. Go register and then come back here and the file will be available 😃
[quote="MR-6T9R"]Actually, nevermind. I figured it consumes less memory by creating a folder and placing the gifs in there and then setting your screen saver to slide show. The screen saver will read the images in alphabetical order so make sure you name the images in sequence eg. 0000.gif, 0001.gif, 0002.gif...... and so forth.
Doing it this way achieves desired effect and plus it doubles up if you happen to want the image(s) on it's own.[/quote]
nice ideas bro! hope u dont mind posting the frames/separate pics here so i can do just what u said. thanks...
