Sending Poloyphonic ringtones
4 replies · 1,761 views · Started 14 November 2002
Hi all,
I was just wondering if it was possible to send ringtones to other phones via multimedia messege? It might be me but I cant seem to send ringtones to my freinds.
[quote="Roysters"]Hi all,
I was just wondering if it was possible to send ringtones to other phones via multimedia messege? It might be me but I cant seem to send ringtones to my freinds.[/quote]
yuo cant send tone (simple or polyphonic via sms) it's a copyright issue, i believe the last phone that can do that is the 3310 :cry:
Does anyone know how to delete downloaded ringtones on the 7650. Example, there are some midi's that I sent to the phone and I want to remove them now. How do I do it?
Thanks,
CJ
go to extra (let say that you didn't change your icon on original setting) go to recorder then you can find the polyphonic ringtones that you send trough your IR and for the monophonic ringtones just go to composer
