Thinking about N70
6 replies · 2,327 views · Started 26 October 2005
Hi, I am new to this forum and I am currently having a 6600, but now I think it is time for an upgrade. I am thinking of N70, but I really don't know. I have two questionnes though:
1. Is it possible to set mp3 as ringtone?
2. How is the battery (maybe compared to 6600)?
Thanks in advance
Metaman
yeah u can set mp3 as ringtones
battery is fine, just make sure u dont have any viruses
BTW i dont have an N70 i have a 6680 but its the same almost, just upgraded,
btw if u do get it make sure u get the one make in finland not china, china models are not as good.
It does allow you set MP3's as ringtones...
As for the battery life compared to the 6600, I couldn't tell you as this is my first Nokia.
However, I can tell you that I am impressed with the battery... I have had the phone for 4 days and charged it twice....
Ok that sounds poor, but considering I have been putting it through it's paces for probably six hours a day either directly or connected to a computer then i think thats good.
A friend has one, he went away at the weekend and used TomTom to navigate his journey. He reckons he got 5 hours and 15 minutes solid use out of it before the battery needed charging.
Again I consider this to be quite good considering the BT was one, and he was running the application constantly.
If anyone thinks this is not so good, please shout!!
Steve
whats the difference with the china ones - ive not checked mine
its a uk vodafone branded one
dont ahve it with me now as im still waiting for teh number port before i can use it
