some thing wrong with firmware v. 05.22(01).
2 replies · 2,210 views · Started 26 October 2005
hello guys. I've a problem with my comunicator nokia 9500.my nokia can't detec my memory card.I don't no why.I think there is a problem with my firmware. My firmware is v. 05.22(01). If i'm not wrong,this is a new firmware.I think there's a bug in firmware v. 05.22(01).Please help me for the solution.Thank's
Try all the basics first. Make sure back cover is on, try the card on another device to see if it is working (or a reader on your PC for example), try formatting (if possible) etc...
If all these (especially trying the card somewhere else) works fine, please state card size and make along with any other relevant info to help get a more specific answer. If it doesn't it may simply be a faulty card. Generarly speaking compatible cards work without any problems (at least up to 1GB size)
Gregory.
http://www.grema.com
ok.i've alreadyread your message.I've try follow your instuction, insert my card in other device.in computer too, but my memory card is okay. My memory is 128MB the original from nokia. until now my comunicator can,t read my Multi media card.Why ?
do you know the best firmware for nokia 9500 Before V 05.22(01) ? maybe i want to upgrade or downgrade. Is it possible to upgrade or downgrade my nokia9500? i think it's all for the qustion. thank you for your attention..
regard,
Jul_e_ha
