hi, just got problem in the voice command. i added a new application WEB in the voice command and tried to change the command. the system accepted the same word WEB which should not be the case as it should prompt that the word is already in use. Now, I cannot delete the application WEB in the voice command.. i got error message "voice system error".
can anyone help me with this error? much appreciated
I have a similar problem with no solution as yet.
I am not exactly sure how my voice system became corrupted yet it may have been when i selected remove my adapts. After this i always get a voice system error when trying to playback a voice command. Also i can not change or add any second text entries to commands anymore. It doesn't save the change or addition. Before this I set up the Recorder with a second tag of "Memo". This can not be deleted or changed either.
BTW: Dialing using voice commands still works but it will not pick up Voice Application commands anymore.
I have tried restoring settings etc to no luck yet.
Anybody experiencing these problems or have any help?
Hi Ezz
I formated my nokia n70 using the code *#7370#. It is now back to the orginal settings, no voice sytem error now.
Thanks! That fixed it for me too.
