Compatabilty with MS Outlook
5 replies · 1,747 views · Started 27 October 2005
I'm thinking of buying a 6680.
Can it be interfacecd well and accurately with Outlooks for Calender and Contacts in particular.
i see that features include "Personal Information Management (PIM)
Advanced Series 60 PIM features including calendar, contacts, to-do list, and PIM printing"
I do this regularly over bluetooth and (once connected which can be a bit of a pain) it works like a dream....
Hi Spinnaker,
I've got a 6630 and it works fine, make sure you do get the latest version of PC Suite which is 6.6 (18) as the previous version did seem to have problems (16)
Andy
PC suite works like a charm. also can sync tasks and notes.
for contacts you must create a sub-folder to sync specific contacts and not your entire contact list (also recommend for notes and tasks too).
I use bluetooth and supplied data cable.
Hi
i have since purchased and after some messing about I've got it working swimmingly over cable
the phone came with PC suite 6.5.12. I downloaded 6.6 however. Seems much improved 😊
still trouble shooting bluetooth
cheers tho
Spin
