Nokia N70 Help
14 replies · 2,928 views · Started 28 October 2005
Hello all, my first post...
does anyone know how to add/edit the 'go to' list. I cannot seem to add shortcuts to it. I am not sure if i understand what the manual is trying to say...
also, my n70 rs-mmc on t-mob came with antivirus preloaded but i accidentally formatted it. called nokia and they said its 3rd party software so we cant do anythign about it... checked symantec website and they want to charge me for it .. can anyone help?
KP1
nip into a tmobile shop - they should be able to reinstall your memory card
to the factory default
Can anyone with a N70 add shortcut items to the 'go to' ?
instructins on page 73 of the manual does not seem to do anything for me
feedback yould be much appreciates from n70 users,
KP
I've had the same sort of problem, it says that you can press options on the app that you want to add to 'go to' menu.
I can only seem to add things like images to the 'go to' menu.
the normal way of putting things on the 'go to' menu doesnt work fort most apps(going into the app> then in a menu selecting go to
try using app man & then in installed software press options & add to favortites
this should add apps to the 'go to' menu
steff2632,
thank for the suggestion, but it does not seemt o work, when i go into the application manager, (via tools - manager) and select the installed application, on clicking the options menu i only have the following options available - view deails, view certificate, remove, view log, send log, settings*, help and exit. there is no option to select add to favourites anywhere, even after expanding settings* option.
Did this actually work for your phone?
my n70 is v2.0537.1.7 dates 18/9/05
steff2632 wrote:the normal way of putting things on the 'go to' menu doesnt work fort most apps(going into the app> then in a menu selecting go to
😉 hi. I'm a newbie and couldn't see how to post, so here I go! I got a n70 and set the caller id to yes so that my friends know it's me, and it just won't show my number. I went into vodafone who said tough, I didn't buy it from them and it's not their prob. It was a present so can't take it back. Anyone out there help?:tongue: pleeeeese :frown:
Go into ;
Tools>settings>call>send my caller id and set it either to "yes" or "set by network". This should do the trick.
Hi
Can anyone give a more detailed guide as to how to use Appman to install application in 'Go To' for N70?
installed apps(the last tab) then a list of the instelled apps will appear(can also include ROM apps) then click options(left soft key) the add to favorites,application is now added to go to menu
Don't have that option... any N70 owner using this application? any idea why no such option? is it because this is not compatible with N70?
