dear friends help me please!
3 replies · 1,877 views · Started 14 November 2002
so, i ha sony vayo p-3, bluetooth tecom usb and 7650.
i have gprs internet via InfraRed port, but i wanna make connection via bluetooth. i setuped, but when i am connecting and dialog "calling" appears on the screen of phone apears bluetooth point "(0)"... and in several seconds apears the string on my computer that modem is not responding in the phone, try to configure it//
what com port i need to edit in bluetooth modem?
what else i need to know?
:angel:
there are different profiles defined in bluetooth, pcsuite e.g. needs the serial port profile... but dial up networking needs the fax/modem profile... the phone won't accept hayes commands / behave like a modem otherwise... so maybe that's the mistake...?
Did you enable all the BlueTooth ports?
[quote="igogo"]so, i ha sony vayo p-3, bluetooth tecom usb and 7650.
:angel:[/quote]
I also had the same problem. Try what the other guys say (check if you are using the correct COM port, etc) and if this does not work, try to make the connection "Authorized" from your 7650 side. This worked for me.
