hey guys
is there any way i can save the .DOC files to my MMC. i transfered a .DOC file via bluetooth and iam not able to save that file to MMC. the fone lets me save the file only in inbox or my folder. is there any other way?
Saving .DOC files to MMC
If you have QuickOffice (QuickWord) installed, you should be able to open the .doc from within Messaging/Inbox and then save it with QuickOffice.
You can also use FExplorer (http://www.gosymbian.com/) and locate the .doc file from under c:\system\mail and copy it to where ever you want (don't delete it with FExplorer, but use the Messaging app for that).
And if you use PC Suite (http://www.nokia.com/pcsuite) you can use its Phone Browser feature to copy the .doc file as a file directly to the memory card, without having to go through the Messaging app at all.
hey thks alot thats app was really use ful. i could do wat i wanted to.. thks
