9500-pcsuite 6.6-blue tooth probelms
1 replies · 1,429 views · Started 31 October 2005
i use 9500- pc suite 6.6- windows xp sp2- widecomm blue tooth software-norton antivirus -internet security.
i tried to configure the phone through connection manager. the phone is not visible.
if i try through the phone the computer recoganises the phone and getting paired. but i can not use the pcsuite.
i was using the same pc suite in my old laptop and was no problem. any help.
YOu should use the "get connected" wizard in PC Suite to pair your phone with PC Suite also(once) only after that the PC Suite will recognise the phone
