Help - Memory Problem
3 replies · 1,272 views · Started 01 November 2005
My N Gage has stpped functioning correctly. It keeps coming up with the message "Memory Full - Delete some Data". I have less data on the phone than when I bought it new. I only have 6 contacts, no text messages and 3 of the default images it came with. It will not allow me to add contacts, recieve texts or use call register. Games still function fine from MMC cards.
Is this a known problem? Is there a fix?
Thanks to anyone who can shed any light on this for me,
Miniwinnie1
use fexplorer or similar program go to c: and look for the directory nokia/installs and if there are programs in here erase them then look for any other installed on phone memory if they are useless erase and setup on mmc.other problems that can cause this are ;directory >> c:/system/app/ there are game save directories in here and sometimes they can become very big files.and the last point is look for directory>> C:/system/data/cbs/cbs2.dat. if this file became very big file you must do hard reset to your phone.but this problem happens on old phones which didnt format long time.thats all.
Hello, everyone this is first sharing in this great forum I found a small program transform all messages to memory card and its a zipped file I try it for n-gage QD and its work fine:icon14:
Attachments: MsvDriveE.zip (974 B)
Thank you so much for all your help. I have managed to free up the memory just in time for my holiday in the US. Means my mum won't worry so much.
I really appreciate everything,
Many thanks,
Miniwinnie1
