guys, do you know how to hard reset and the code too?? my comunicator can,t detect my MMC. if can detect, it's so slowly. For example after i input my MMC to my 9500. i go to file manager.there's no my memory card. After more than 1 hour, my 9500 detec it.i don't know why? My latest firmware is V 05.22(01). Help me guys 😃
thank's a lot....
how to hard reset?
ctrl +shift+f while device poweron
First Remove the Battery.. then Put it back to make a reset..
..then while Your phone is Booting up Press n hold ctr + shift + F .. then it will ask you if you want to format your phone...
.... hope this helps. 😊
thank you nicola13 and usharani
😊 my 9500 more powerfull now😃
hi guys,I can't seem to install downloaded themes says installing security error
and stops any solution?
