Urgent-"Symbian connect" for Symbian 6.1
6 replies · 2,309 views · Started 15 November 2002
I need the downloadable Symbian Connect PC software for downloading applications from my PC to my Symbian 6.1 device. Is there any alternative way of downloading apps to the device? I do not have IR or bluetooth facility. Please help.
Regards,
Ashwini.
😃 😊 😞 😮 :x 😃 8) 😃 :-? :P :roll: :agrue: :bday: :black: :robot: :angel: :fadein:
What magic do you expect "Symbian Connect PC software" to do, if you have no infrared or Bluetooth on your PC (and the 3650 only has infrated or Bluetooth connectivity to PCs)?
Nokia's PC Suite is for this purpose, but it does need either infrared or Bluetooth as there is no supported cable connection you can use.
However, if you have email set up, or a WAP site, then you can get & install software through either of those mechanisms.
A third option is through a PC-based MMC card reader/writer.
Try to program directly into phone.
Use keyboard to program it : 0001010111101010011110010101011111010101011
Exist one way, to transport program into phone without BT or IR.
You must open file in PC and show as BIT source.
Now you must create empty file in the phone.
Now you write 0 and 1 into new file etc:
01011100111010110101110101.....
:bday:
