I am wondering if TomTom Navigator (for PDA) would work on Nokia 6620, or it has to be TomTom Mobile 5 ?
I understand that 6620 can use the maps come with the Navigator.
The PDA version will not work on your 6620. You'll need a SIS installation designed specifically for Symbian S60 phones to handle the maps and navigation, then you should be able to transfer specific maps to the phone. A bluetooth GPS receiver is also required.
