It took them only a week to post the file. Way to go, Nokia! ![]()
All_Nokia_9210_data.sis for firmware 4.13 is finally on Noki
Every time i try to install this sis.file on the D drive, i get an error.
-cannot find pc mail. try to reinstall
I get the same message about the fax.
What am i doing wrong!!!!
All_Nokia_9210_data.sis is intended to be installed on C drive ONLY!
I tried to install on C and D.
Both doesn't work, so i called Nokia.
They said Pc suite isn't compatible with windows xp or me, so I installed windows 2000 wich is compatible he said.
I downloaded the file again to be sure it is ok.
I formatted the divice and the memorycard.
Again i tried to install on C or D with exactly the same error.
During installation it said "close active programs before installing pc mail initialision, yes or no.
I choose yes and it continued installing.
This is were i get an error on the screen of the communicator. "There is a problem with the installation of pc-mail, the map could not be found. install again".
I get the same error a few seconds later when it is trying to install Fax initialisation.
Is there someone who did installed this All Nokia 9210 data v4.13.sis file at his communicator with firmware 4.13 without problems?
Ren�
Perhaps you could try it copying the sis file onto your MMC or your comm, and installing it from there without PCSuite.
I tried that this morning, it doesn't work.
BUT; i just found out what was the problem.
You have to install the All Memory card data v4.13.sis first.
This installs the support for;
-Fax
-Fax initialisation
-pc mail sync
-pc mail initialisation
After the All Memory card data you can install the All Nokia 9210 data v4.13.sis without any problems.
It took me for about 12 hours to find out!
Maybe this could help others with the same problem.
Thanks for the suggestions!!
Ren�
Damn! It�s good to know it! Thanks!
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
Ren�
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
Hi Ren�,
So, did you install to the C or D drive in the end?
BR
db
I tried at C first., it did work.
So i formatted everything and start all over again, installing both files ( all nokia and all memory card) at the D drive.
I got no errors or loss of speed.
Now I installed all office vieuwers and bounce with LP1 and LP2.
Still no errors or loss of speed.
After installing both extra fonds (NCR, NTM) i got an error when i try to install the next sis file.
It refuses to install and i have to restart my PC and 9210 To get a working connection between them.
If i ignore this the errors keep coming back.
how can i solve this problem?
I need both of the fonds for citymaps europe.
Ren�
