Transfering files
2 replies · 1,526 views · Started 04 November 2005
1) The quickest way is use your memory stick and a card reader.
2) Also, If you've installed the software that comes with the phone on your PC, then when you connect (to the PC) you can drag and drop files between both devices. Simpley double click on the p910 icon on your desktop..
DT
Thanks... sometimes the easiest solution is starring you in the face and you can't see it for your self...😉
