Hello,
I've been trying to develop some skins for UltraMP3 and have been semi-successful. The only problem is that the 'buttons' for "menu" and "exit" functions are missing. It seems this is probably because the file spr_a.pcx is missing...
This is not included in the skinning tutorial from the manufacturer and I was wondering if anyone might know where to locate it?
...thanks...
Nevermind. You can just download a skin from your phone to computer and do it that way. I am, though, having problems changing the colors of the volume and number sprites...
If anyone can help with THAT...
That problem is solved. Use the .psd format supplied from Lonely Cat & note that there are 2 layers. (They mention this, layer 1 and rects). The catch is that layer 1 has 2 parts, the layer and the mask. Make sure the layer is selected and then it can be colored as normal.
NOW, when I zip this thing up with the rest of the skin files...why does UMP3 keep resorting back to the old sprite colors???
