Hi all. I know this may be obvious, but i'm new to this series of phones. Is there anyway to strip out the Vodaphone icon from the top right hand corner of my screen.... it's ruining the themes i've just paid for!!! Thanks.
6680, Operator logo
Only if the Vodafone version of the phone allows you to set/change operator logos.
If it does, you can, among other things, use FExplorer (http://www.gosymbian.com) to set or remove operator logos. User-definable operator logos will be bitmap (.bmp) files in c:\System\Apps\phone\oplogo on the phone.
