6600 wont read memory card.......!
1 replies · 1,908 views · Started 07 November 2005
Please can someone help me...........?
My Nokia 6600 says my MMC 128mb memory card cannot be read by my phone.... when selecting it from the 'Gallery' tab........it reads 'no memory card inserted...'
Help me plz
If your phone can't read it, i'd suggest using a PC card reader to check if the card is readable from windows, and backup any data that you might be able to pull off it.
Your best bet is to then use a little program called MMC Medic (google it) to fix the card, or simply buy another one, as there isnt much you can do to fix a solid state device like a memory card.
