Failure using Canon BJC-85 !!!
3 replies · 2,178 views · Started 15 January 2002
I can�t getting my printer to work with the 9210 when select the Canon Bubble Jet in the printerlist, only letters to left side appers. The Ir port works OK with the PC Suite and the printer OK with my 9110.
Looking forward to any help
Frank
You have to set the printer to "Canon Bubblejet (LQ mode)" and you will find it will work with the BJC55.
Nokia on the cutting edge.
Good luck
Symbian have always been a bit of a pain with printer drivers.. after all it supposedly not a priority on a wireless phone... you have a paperless office dont you User posted image yeah right!
As the above post said for the fix.
Rafe
