Is there anyway so that i can use my 3230 as pendrive (the feature is available in LG G1800 60 MB pendrive). Do i need to install any software 4 that?
3230 As Pen Drive
If you install Nokia PC Suite (http://www.nokia.com/pcsuite), then you can use the "Phone Browser", which is a Windows Explorer extension, to access files on the phone (phone memory or memory card).
The 3230 does not have, so called, USB mass storage support and without that support you need something like PC Suite to make it visible to the PC.
And you (or any user-level application developer) cannot add the USB mass storage support to an existing device, if it isn't present on the device originally.
As the 3230's RS-MMC card can be easily remove from phone, I would suggest you to buy an adaptor with a SD card reader slot with an USB plug.
Slot your RS-MMC into the reader and plug in the USB port, walla, the cards now works similar to a USB Drive (or PenDrive) 😊
