Bit of a problem...
i have lost/forgotten my lock code....
Not in itself a problem, as the phone is not locked, but what do you suggest?
Bit of a problem...
if its NOT a stolen cellular, you can take it to your local phone-dealer. Or you can make a phonecall to your Service-Provider and ask them for a lock code. You can hack the phone with proper software and change the code (dont ask). last you can just lay it as it is, if its locked up you can open it with your cell-operator. If its stolen phone, youre in deep shit. 😃
mrC64
No its not stoen, I am just a muppet that can't remember numbers (tip: never mess with lock codes when drunk...)
Its not the SP lock code (the sim code)... its the software lock code.... i.e. the one set by the operating system...
