N70 Memory Cards
7 replies · 3,498 views · Started 08 November 2005
I have just upgraded from the Nokia 6630 to the N70 and am wondering if the memory card for the 6630 will also work in the N70 as I have all my games and applications saved on it.
Does anyone know??
Thanks in advance
Is the card in your 6630 Reduced Size? If so then yes it will, if not i'm afriad you'll have to transfer it all across to the new card.
sorry jimbob i'm not the most technical when it comes to phones.
What do u mean by reduced size? it was the one that i got when i upgraded to the 6630. can i not just take that one out and put it in the N70?
If not, how do i go about transferring it all?
Thanks for your help
Is the card you got with the N70 the same size as the one as you've got with your 6630?
If so I cant see why you cant put your old mem card in the N70.
Basically your have a mmc and a rs mmc. One is full sized and one is reduced size. When you got your N70 it would of come an extension to make it full sized mmc.
Just checked the Nokia website and yes you can use the mmc from your 6630 in the N70. Just slot it in the side and your away.
It will depend on whether the card is dual voltage or not. I suspect it may not work if it is not an MMC Mobile card.
lets get this settled, both phones use dual voltage reduced size multimedia cards or MMc mobile (mmc mobile is just faster and is newer, but backwards compatible) so yes it will work. they are not normal rs-mmc's if u try to put an rsmmc in the phone it wont even detect it.
