First i thought that i have the white screen of death problem, but it maybe isnt..
My N-Gage turns normally on, and asks pin-code and so on.. but after about 5 to 15 secs it _fades_ all graphics from the screen to white screen. then it restarts itself and do the same thing... wery odd..
seems like it doesnt get enought power or something..
The problem appeard when i chanced from clock options to update time automatically when phone starts...
does anybody hav the same problem?? can anybody help?
n-gage is such a great device, but it seems to have lots of problems :/
please help if you can!!
Have u try with
-safe mode with or without mmc?
-hard format?
-take to nokia?
Have u try with
-hard format?
-take to nokia?
rulirahm wrote:Have u try with
-hard format?
-take to nokia?
thanks for reply
if safe mode is "press pen-key when startup" it isnt working..
i cant hard-format because the phone doesnt keep on that much time that i could insert *#7370#..
i have also another problem with hard-format.. i dont know the security code for the phone because the phone was used when i bought it.. (not from store)
(it isnt 12345)
maybe my only opinion is nokia repair center.. if they dont mine that i dont got the security-code.. if they think that its stolen or something..
ohh sorry my english.. cant think clearly, last night went over 😃D
but tell me please if you got some hints for me!! i must use 7650 now.. its good phone too but its memory sucks.. no mmc 😞
(it isnt 12345)
Well, nothing u can do with ur phone and u must take it to nokia repair center. They won't think like that.
