nokia 3230 with nokia pc suite problem
4 replies · 2,715 views · Started 09 November 2005
Hai !
I am having nokia 3230 and i have installed nokia pc suite 6.6 on my windows xp . when i plug my dku2 cable pc suite says connected via 3230 connected via usb cable but while i tried to browse my phone contents it says could not connect to the phone . I tried uninstall pc suite ,driver files and reinstall it but the same problem occurs.Please help me to rectify this problem
thanks
Have u meet all the requirements?
PC System Requirements for Version 6.6
* Available hard disk space: 250 MB (file size approx 25 MB)
* Operating system:
o Windows 2000 (service pack 3 or service pack 4)
o Windows XP (Professional or Home Edition) (service pack 1 or service pack 2)
* Connection methods: USB cable, infrared, or Bluetooth
* Supported Bluetooth software (Bluetooth stacks):
o IVT BlueSoleil Bluetooth stack for Windows XP/2000 (driver version 1.6.1 with release version 05222 or newer must be used)
o Microsoft Windows XP Bluetooth
o Toshiba Bluetooth 3.0x
o WIDCOMM Bluetooth for Windows 1.4 and 3.0
Right-click the Bluetooth icon in the Windows tray and select Advanced Configuration. On the General tab you can see the version of the stack.
To see the cables and connection methods supported by your phone model, see Features Supported by Your Phone.
http://nokia-asia.com/nokia/0,,78344,00.html
i've experienced the same problem, too, after few time investigation, and finally, i found the wireless network adapter (dell truemobile 1300) of my laptop has some conflict with the nokia pc suite.
if i disabled the wlan adapter aftere windows reboot, there is no any problem of pc suite, it will be very easy to connect to my nokia 3230, then i can enable my wlan adpate to connect to the internet.
but if i disconnected the link with my 3230 when the wlan adapter enabled, then i will not be able to re-connect to 3230 again, and i also can not disable the wlan adapter anymore.
for ur reference!😊
I have exactly the same problem, it says the phone is connected and i can sync my contacts onto my computer but nothing else works, getting images does nothing and file manager says operation is not possible. Really annoying me because I ordered a 512mb mmc but without being able to transfer photos to my pc and songs etc onto the phone its pretty much doing nothing.
It happened to me today .. and I found antoher solution..Just delete the paired device(your computer) from the settings on the phone😊 in menu>>bluetooth>>paired devices😊 Then add it again..it will ask for passkey and that's it 😉
